Battery drains overnight, parasitic draw?
134,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
DOUGPARKS567
  • 60 POSTS
Hello, I'm having an issue with my battery draining overnight. I'm getting current draw from fuse #7 inside driver side compartment fuse block. I was wondering how do I pinpoint the draw when the fuse controls multiple components. One of which is the BCM which controls multiple components. Any idea what could be the culprit?
Aug 6, 2022 at 11:02 PM
  • 110,248 POSTS
Since the drawer could be before the BCM, try disconnecting it to see if the draw goes away. If it does, then reconnect the BCM. One component at a time tied into the BCM will need to be disconnected to see when the draw stops.
Here is a link that you may find helpful:
https://www.2carpros.com/articles/car-battery-dead-overnight
Let me know what you find.
Aug 7, 2022 at 4:26 PM
DOUGPARKS567
  • 60 POSTS
Okay, I came back to the truck and put #7 fuse back in to see if there was a draw. Strange thing there isn't a draw now, but my power-locks aren't working. I haven't tried unplugging the BCM. Should I disconnect the battery first before I unplug connectors to BCM and remove?
Aug 8, 2022 at 8:56 PM
  • 110,248 POSTS
Yes, I feel that it is a good idea to disconnect the battery first. However, if there is no draw at this time, the test would be moot. Were the locks working prior? I ask because you may have already identified the draw.
Aug 9, 2022 at 5:09 AM
DOUGPARKS567
  • 60 POSTS
No, the locks weren't working prior. I'm thinking maybe issue with door module. It's only the front two doors they won't lock or unlock. I have to lock and unlock them manually. The rear doors and liftgate working fine.
Aug 9, 2022 at 9:29 AM
  • 110,248 POSTS
It could be the DDM. I looked through the schematics and there are splices, but power all comes from the same fuse. Also, they share the same ground except for the left rear.
I attached the wiring schematics below so you can reference them. Note there are three wires at each lock actuator. The one I didn't highlight is the door ajar switch. The actuator either locks or unlocks based on polarity. If you send the power in one direction, it locks and the opposite.
Also, you may want to scan the can-bus. CAN stands for controller area network. Basically, the modules are tied together via a few wires. This type of scan will provide codes regardless of the module storing them. Here is a link showing how it's done.
Let me know your thoughts.
See pics below. Note: I had to cut the schematic in half to make it readable for you. I did overlap the two so you can follow from one to the next. Also, I highlighted all wiring related to the door locks for you.
Aug 9, 2022 at 1:16 PM
DOUGPARKS567
  • 60 POSTS
Okay, thanks Joe, will look into this tomorrow after work!
Aug 9, 2022 at 2:10 PM
  • 110,248 POSTS
No problem whatsoever. I hope it helps. Let me know if you have questions or if I can help.
Aug 10, 2022 at 4:06 AM
