Hello. I have received some excellent guidance on your website. So, thank you in advance.
Problem: Battery drains after sitting for days. Battery will recharge. However, it will die again after sitting for a week or so.
To diagnose the issue, I used a multimeter and removed a couple of fuses from the rear fuse box. One that was drawing too much current was linked to the AC Heater/Cluster/Security Module. This is where the diagnoses ends. I am not sure if I should be looking at the A/C relay or something else. I know where the relay is, and I am trying to set up my next course of action. I want to have several ideas in mind, before setting myself up for disappointment. Anything you can suggest? Thank you much.
Edward
Edward
Sep 6, 2021 at 8:14 AM
