parasitic battery drain
134,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
MATHGUY
I have a 165 mA draw that goes away when I pull the 40 amp fuse in the power distribution center (under the hood) that is labeled IGN feed. Could you give me some possible causes? Thank you.
Mar 22, 2017 at 1:11 AM
WRENCHTECH
  • 20,758 POSTS
The service manual labels these fuses by number, not name so I need the fuse number.
Mar 22, 2017 at 3:36 AM
MATHGUY
Found the problem! Remote start that po had installed went bad.
Mar 22, 2017 at 12:15 PM
  • 55,770 POSTS
Glad you could get it fixed please use 2CarPros.com anytime we are here to help
Best, Ken
Mar 27, 2017 at 8:12 AM
