Parasitic battery drainage
32,305 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
JOHN ROUND
The car has an alarm and tracking module installed. I only drive the car a short distance and once a week. Since I started doing that the battery (680Ah) drops below the 12V voltage needed to start the car after 7 days. What is the best option to follow? 1. Buy a jump starter to start the car when the voltage drops below 12V or 2.Buy a battery with a bigger capacity.
Mar 19, 2021 at 10:20 PM
Good afternoon,
The battery is too small. You need one with a larger capacity. I would get one with 800. the standard is the 680 but that is for everyday use.
https://www.2carpros.com/articles/how-to-replace-a-car-battery
That will last about 3 weeks before going down.
Removal and Installation
1. Disconnect the battery negative terminal (B) first, then the positive terminal (A).
Tightening torque :
(+) terminal (A) : 7.8 - 9.8N.m (0.8 - 1.0kgf.m, 5.8 - 7.2lb-ft)
(-) terminal (B) : 4.0 - 6.0N.m (0.4 - 0.6kgf.m, 3.0 - 4.4lb-ft)
2. Disconnect the vent hose (C).
3. Remove the battery upper bracket (A) and then remove the auxiliary 12V battery (B).
Tightening torque :
19.6 - 29.4N.m (2.0 - 3.0kgf.m, 14.5 - 21.7lb-ft)
4. Remove the battery tray (A).
Tightening torque :
5. Installation is the reverse order of removal.
CAUTION:
Install the battery upper bracket after locating the battery at the closest position to the side panel.
Mar 20, 2021 at 3:07 AM
Did you respond? I got an email but nothing came through.
Mar 21, 2021 at 9:30 PM
JOHN ROUND
I responded thanking you for your answer . I am searching now for a 80Ah battery which is more than the 68Ah I have at the moment. Hope this message will get through.
Mar 21, 2021 at 9:38 PM
Got it this time, thanks.
Keep us updated with the results.
Mar 21, 2021 at 9:46 PM
JOHN ROUND
Will do Roy.
Mar 21, 2021 at 9:48 PM
You are welcome.
Always glad to help.
Mar 21, 2021 at 9:49 PM
