Bought it knowing it has a panoramic roof problem, it was stuck open. The fabric cover opens and closes with no issues. I pushed the glass to close it and i got it to about 85% closed then noticed that there is a metal round pin on each side under the glass that the piece that is supposed to push it open and close is supposed to attach to it. I then used the power button to see what happens and the roof moved back all the way without an issue, but to close it the pieces on both ends move but the roof doesn't. If am not mistaken those pieces are broken on both sides. Can you look at the pics and recognize it? Also, is this a common problem you have seen on these cars?
May 25, 2021 at 11:35 AM
