panel lights going off every couple of seconds
122,000 MILES • V8 • AUTOMATIC
JBARRAG
On our panel the light goes off every couple of seconds and it says the door is ajar and all of the doors are closed properly. We checked and double checked and the doors are closed. We are having trouble with the back passenger doors opening but the doors are closed. Thanks for your help.
Jul 3, 2015 at 3:35 AM
WRENCHTECH
  • 20,758 POSTS
The switches that control the lights for open doors are made right into the door latches and they have a history of sticking and causing problems like that.
Here is a technique that often works well and eliminates the problem at no cost.
Get a can of spray lube like WD40 or something like it and has a straw on the nozzle. Spray it generously up into the latch mechanism. Now open and close the door numerous times to work it in. Repeat this process several times. Since you don't really know which door is causing the problem, you should do all of them. It's usually caused by the most frequently used door but it's not guaranteed to be that one.
Jul 3, 2015 at 9:54 AM
