PAG oil?
187,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JHEND1
Just watched.
How to Vacuum Down and Recharge Your A/C System!
How come the Oil isn’t evacuated with the Freon?
Jun 6, 2023 at 4:12 AM
CARADIODOC
  • 34,414 POSTS
Pumping the system into a vacuum is done to remove any moisture from the system. In a vacuum, water boils at 77 degrees Fahrenheit. It gets pulled out as a vapor. Any refrigerant has been long gone by that time. It boils somewhere, as I recall, at around minus 70 degrees. The oil doesn't vaporize so it just sits in the system during the entire process.
Jun 6, 2023 at 7:20 AM
