pacifica front wiper cliking and the cluster blink
162,000 MILES • 3.5L • 6 CYL • AWD • AUTOMATIC
HECTORP
FRONT WIPERS DON'T WORK (BUT BACK WIPER WORKS). ALSO IF I PUT THE WIPER IN ON THE LIGHTS ARE ON AND OFF THE DASH. TRUCK ONLY OPENS WHEN THE CAR IS ON H. LIGHTS ALSO WORK WHEN THE KEY IS OFF. I HAVE A MULTIMETER BUT I CHECK FIRST THE BATTERY,ALTENATOR ,ALL FUSES,GRONGS UNDER THE BATTERY TRAY.I SWAP ALL RELAYS AND THE PROBLEM STILL. I DONT BELIEVE THE PROBLEM IS IN THE FUSE BOX ITSELF OR VOLTAGE.THIS PROBLEM CAME AFTER REPLACE THE AIR COMPRESOR/COIL/BLOWER MOTOR, PLEASE HELP THANKS
Jun 25, 2015 at 8:25 AM
HMAC300
  • 48,601 POSTS
have a local pro scan for codes see if your tpim module is bad.
Jun 29, 2015 at 11:55 PM
HECTORP
Really,for free I don't expect good answer ,Thanks
Jun 30, 2015 at 6:51 AM
HMAC300
  • 48,601 POSTS
if you happened to know anything about eh way Chrysler products are wired the front wiper goes through the tpim module which Is normally called the intergrated power module and the rear wiper motor goes through the body control module. I could have told you to replace the wiper motor as well as multi function switch which if you didn't get it scanned would be a total waste of money on your part. complain to Chrysler on the way their products are wired.
Jun 30, 2015 at 8:36 AM
