p2646 code
158,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
WARRENG92837
I got a code back for a 04 Honda accord ex that says P2646 Rocker Arm Actuator Control System Performance /stuck off / (bank 1)
Where can I purchase one and what exactly is my problem . Advance doesn't sell them.
Feb 21, 2016 at 11:59 PM
THIS IS MIKE
  • 686 POSTS
Check your engine oil level, low engine oil will cause that trouble code. Also check your valve timing solenoid, try cleaning the solenoid and the filter. Clear the code and see if that takes care of it, if not your VTEC oil pressure switch may have failed. It could also be a faulty oil pressure switch sending incorrect information to the ECM/PCM
Feb 24, 2016 at 5:58 AM
