Hello. Here is all of the information that I have on P2627. It is essentially that the signal voltage from Bank 1 Sensor 1 is low/nonexistent. It would probably behoove you to take a close look at the wiring for it, including running continuity tests to see if there is a short circuit somewhere. You might also swap the sensors around (bank 1 sensor 1 and bank 2 sensor 1) to rule out the possibility of a dud of a sensor. It is rare that sensors come bad straight out of the box, but it does happen.
Let us know what you find and we will go from there.
Images (Click to enlarge)
Sep 22, 2018 at 10:17 PM
