Codes p2432 and p050b
100,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
68BILL
Engine started running rough very little throttle response. lightning bolt came on plus p0171 code, I assume limp mode. replaced mass airflow by air cleaner then set a new code p2432 symptoms never changed checked relay, airflow sensor and air pump everything checks out good all wiring is good now its setting a p050b code as well I assume in relation .
there is no power after relay going to pump after start up so air pump is not coming on but there is power going to relay.
Feb 9, 2020 at 6:13 AM
JOETECHPRO
  • 705 POSTS
Hey 68BILL,
Can you please check fuse 26 in the TIPM?
I have attached a fuse diagram and description of TIPM location.
A guide below will run you through testing the fuse.
Let us know how you go and we can run through further testing.
Regards, Joe
Feb 9, 2020 at 2:13 PM
