Code P229f knock sensor?
79,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
MEELYBUG
P229f code. Replace knock sensor, the code returns. Should there be a learning in process for the sensor?
Apr 26, 2018 at 11:04 AM
STEVE W.
  • 15,418 POSTS
No learning process. A common cause for that code is a fault in the actual harness. Usually from a corroded connector. Does the engine make noise while running? THis can trigger a false code fromt he knock sensor. Can you please shoot a quick video with your phone so we can hear the noise? that would be great. You can upload it here with your response.
Apr 27, 2018 at 4:44 AM
