Code P2177?
118,800 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
KVANHORN00
About a month ago I had to replace the belt on it and reinstall the tensioner bolt after both came off of the car while driving one day. I've replaced the camshaft position sensor, the belt, the VVT Solenoid and a few other things. I know my coils, spark plugs, MAF Sensor and Injectors are all good.
I now have code P2177, which I know is Too Lean Off Idle. The issues I have are an erratic idle at startup and it evens itself out, light smoke coming from exhaust, and when I go to accelerate it will hesitate and then shoot forward like I slammed on the gas.
I cannot figure out why it's still having those symptoms, the only thing I can think of is that might need to replace the PCV Valve/Membrane.
Jun 6, 2023 at 1:52 AM
BORIS K
  • 836 POSTS
The P2177 code means that the system is too lean off idle for bank 1. The ECM constantly monitors the air-fuel ratio, and when it is found to be too lean off idle for bank 1, the Check Engine Light is set.
Possible causes that could set p2177:
Engine misfires
Faulty readings from the oxygen sensors
Air leaks in the intake
Low fuel pressure or not enough fuel
Fuel injector that has failed
MAF sensor is faulty
An article:
https://www.2carpros.com/articles/engine-hesitates
Please let us know if you require anything else.
Cheers, Boris
Jun 6, 2023 at 2:32 AM
