About a month ago I had to replace the belt on it and reinstall the tensioner bolt after both came off of the car while driving one day. I've replaced the camshaft position sensor, the belt, the VVT Solenoid and a few other things. I know my coils, spark plugs, MAF Sensor and Injectors are all good.
I now have code P2177, which I know is Too Lean Off Idle. The issues I have are an erratic idle at startup and it evens itself out, light smoke coming from exhaust, and when I go to accelerate it will hesitate and then shoot forward like I slammed on the gas.
I cannot figure out why it's still having those symptoms, the only thing I can think of is that might need to replace the PCV Valve/Membrane.
Jun 6, 2023 at 1:52 AM
