Check engine light on and code P2138
150,000 MILES • 6 CYL • AUTOMATIC
STARLORD1976
  • 173 POSTS
What is the problem and how do I fix it?
Aug 16, 2020 at 6:38 AM
Good afternoon,
The most common cause the the pedal sensor on the fuel pedal. It is a simple fix and the part is available from your local parts store.
1. Remove the left instrument panel (I/P) sound insulator.
2. Disconnect the accelerator pedal position (APP) sensor electrical connector (1).
3. Remove the APP sensor assembly bolts.
4. Remove the APP sensor assembly from the vehicle.
Aug 16, 2020 at 6:53 AM
STARLORD1976
  • 173 POSTS
Is this the part here in pic. This is all that shows up?
Aug 16, 2020 at 7:24 AM
That is correct. That is the part.
Aug 16, 2020 at 7:41 AM
STARLORD1976
  • 173 POSTS
I erased the code on it and the engine light went off and hasn’t came back on yet, is that a good thing?
Aug 16, 2020 at 1:16 PM
Erasing does nothing. The code will return at some point. The issue was there and is still there.
It is a matter of time before it comes back.
Aug 16, 2020 at 8:36 PM
