Intermittent code P2135
95,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
DJTESTOR
Hello, I'm having an intermittent issue with my car. Hope someone that knows Hondas might be able to shed some light.
So, the problem started a few years ago, driving along and then money light came on, pulled code p2135. The engine still ran fine and there were no noticeable symptoms. Took the car to a local garage, and they pulled a few other codes on top. There was an ABS low voltage and an ECU incorrect function. We decided to send the ECU off to have it checked. I was told the ECU was fine, and that they had re-flashed it, it's been a while so i don't remember exactly what the mechanic said. Anyway, the car ran like a dream for just over a year after that.
Jump forward to 4 months ago, once again driving along money light came on but this time the engine started acting all sorts of weird. Power followed by no power, revving without the pedal been pressed and hunting. Pulled code P2135 again. I decided to take the car to Honda. They did a diagnosis and said it was the throttle body, quoted £1400 for a new one. Decided to get a second hand one instead, performed an idle relearn and all was good for a few months.
Then P2135 happened again, all the same symptoms as before. This time i bought a new pedal sensor and another secondhand throttle body. The car lasted about five miles before the same thing happened again.
Took the car to a recommended local garage, they reset the throttle position and said because i had put in a new pedal sensor the two were not matched. The car lasted about 2 weeks and yet again another P2135. The garage has checked all the wires and connectors but can't get the code to happen again to find out where the fault is. We decided to pull the ecu again and it's currently away for testing.
My concern is, that if the ECU is fine, am i just unlucky with the secondhand throttle body's or is something else at play here, like a relay or fuse?
Many thanks for taking the time to read this and hoping you can shed some light on this pain.
Jun 23, 2022 at 10:40 AM
  • 55,691 POSTS
Yes, I don't like using secondhand parts for the throttle system, but there is a throttle actuator control module I would replace because they go bad and can cause this code. Here is the location and how to replace it in the diagrams below. Check out the diagrams (below). Let us know what happens and please upload pictures or videos of the problem.
Jun 24, 2022 at 3:19 AM
DJTESTOR
Many thanks, i will look into this as soon as the car is back in my hands, hopefully this coming week. I'm not a fan of putting in secondhand parts myself but $1,400.00 is way above what i can afford right now. Will report back ASAP.
Jun 24, 2022 at 4:37 AM
  • 55,691 POSTS
sounds good.
Jun 25, 2022 at 5:20 AM
DJTESTOR
Sorry this reply has been so long in waiting. The car is back in my hands now. I have replaced the module in question, car seems to be running fine with it. Unfortunately it may be days weeks or months waiting to see if the problem comes back. I have not got any pictures or videos of the problem, but should it arise again i will endevour to take some.
Also i bought myself a decent scan tool so that i can recalibrate the TPS should it happen again, as thats what the garage did and would solve the problem for a time. If the module in question is faulty, would it be a case of the module not activating the throttle plate intermitantly and over time this would cause the sensors to read out of place?
Many thanks.
Jul 29, 2022 at 8:38 PM
  • 55,691 POSTS
That is hard to say because the unit all inclusive. Make sure the connector is clean with no corrosion. Let me know if the problem comes back.
Jul 30, 2022 at 6:28 AM
