P1811 transmission code
138,437 MILES • 3.4L • 6 CYL • FWD • AUTOMATIC
RADLEE GARSKE
The car shifts fine sometimes but other times it shifts hard and then jerks a little bit. A mechanic said my transmission is going out, so I have no clue. Anything helps? thank you.
Mar 2, 2017 at 9:33 AM
HMAC300
  • 48,601 POSTS
1811 means long shifts between gears. have a transmission professional look at this as it may be low line pressure or sticky valve body. if it continues it will need a rebuild.
Mar 2, 2017 at 11:23 PM
