p1443
285,000 MILES
BMXWAYNE
  • 58 POSTS
what are all possible causes of the code p1443 evap canister purge low/no flow and what are the most common ones the purge valve was replaced a couple of years ago and one of the hoses just the other day what all testing can be done to check all possibilities
May 12, 2013 at 12:13 PM
HMAC300
  • 48,601 POSTS
get a smoke test done on the system that will tell you whats wrong. check to make sure your gas cap has at least 3 clicks after a fillup
May 13, 2013 at 12:07 AM
BMXWAYNE
  • 58 POSTS
i was wanting to know what all i can do my self to diagnose the problem and not take it to a shop
May 13, 2013 at 12:26 AM
HMAC300
  • 48,601 POSTS
it has to have a smoke test to see where it 's blocked unles syou wan tto try spending money on a evap canister purge valve and seeif it fixes it but you'llneed a scanner to erase the code.
May 13, 2013 at 12:27 AM
BMXWAYNE
  • 58 POSTS
how can i do a smoke test on my own i am trying to save money by not going to a shop because i am on a very tight budget
May 13, 2013 at 12:30 AM
HMAC300
  • 48,601 POSTS
you can't it's specialized equiptment. it is nt' smoke anyhow.
May 13, 2013 at 12:32 AM
