P1441 evap system flow during non purge
5.7L • V8 • 4WD • AUTOMATIC
JESSARIE
Truck is missing and backfiring while in drive or reverse or under a load. Our solus pro scanner found this code p1441. Need to know what is wrong and how to fix it. Thanks.
Jun 28, 2015 at 8:05 AM
HMAC300
  • 48,601 POSTS
that is evap system purge is flowing when it shouldn't check canister purge solenoid for being open. also check fuel pressure then basic engine checks. may be a bent pushrod.or ignition problem.
Jun 29, 2015 at 12:57 AM
