Check Engine Light turned on with code P1381?
271,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
BENLEE1199
  • 82 POSTS
Hello, my check engine light came on while driving home from work today. The engine was running perfectly normal, both before and after the CE light came on, so there are no symptoms to mention, and the engine is running great. I got just one code, which is P1381.
What would be the most likely causes of this code for my make and model?
If you could point me in the most likely direction(s), that would be great! Thank you!
Feb 7, 2024 at 8:21 AM
  • 55,766 POSTS
The P1381 code in your 2001 Honda Accord is related to the Cylinder Position Sensor which is location down at the crankshaft in the front of the engine behind the timing belt cover. Sometime the wiring can get messed up due to the timing belt coming apart. Check out the images (below). Let us know if you need anything else.
Feb 8, 2024 at 2:51 AM
BENLEE1199
  • 82 POSTS
Thanks for your response, Ken. Before I saw your reply, I had done some other research online and saw that some people suggested double checking battery terminals and cables, as well as the alternator, since they said this code can sometimes be triggered by voltage issues. There was some corrosion on the terminals, but not much, and the negative battery cable was not 100% tight, so I took off both terminal connectors, cleaned the connectors and the terminals, and put them back on. Then I started the car so I could check the voltage at the battery while running, for the sake of checking the alternator. The voltage was 14.35 with the engine running and no accessories on, and with the headlights on and blower fan (just fan, not AC) it was 13.95. I also went ahead and plugged in my code reader while doing this and noticed that the check engine light turned itself off and the reader said there were no codes, so I guess the ECU no longer saw the fault and cleared the code on its own.
I thought I was in the clear, but then when driving home from work the same day, after about 45 minutes of driving, the CE light came on again. The difference this time was that I did notice some engine surging about 2 different times after the CE light had come back on, but I still had another 30 minutes of driving and the engine felt fine for the rest of the drive.
Anyway, not sure if any of this information helps or perhaps points to something other than changing out the Cylinder Position Sensor or repairing its wiring.
Thanks!
Feb 9, 2024 at 12:19 AM
  • 55,766 POSTS
When the check engine light came back on, did it have the same code?
Feb 9, 2024 at 1:35 AM
BENLEE1199
  • 82 POSTS
Yes, still P1381. No other codes.
Here is the freeze frame data from the 2nd time the code came on:
FUELSYS1: OL-Drive
FUELSYS2: N/A
LOAD_PCT(%): 16.1
ETC (F): 181
SHRTFT1(%): 0.0
LONGFT1(%): -1.6
MAP (inHg): 4.7
RPM: 1951
VSS (mph): 50
IAT (F): 122
TP(%): 9.8
(I did not save the freeze frame data from the 1st time the CE light came on)
Feb 9, 2024 at 2:49 AM
  • 55,766 POSTS
These readings are strange, could be because of the crankshaft sensor or you have a bad PCM.
RPM: 1951 - was the engine at a high idle?
VSS (mph): 50 - were you driving it at 50 MPH when you did the scan?
IAT (F): 122 - do you live in the hot desert?
If not, I would get a rebuilt PCM, you can get a preprogrammed unit by searching Google or Ebay.
Here is the location of the PCM. Check out the images (below). Let us know how it goes.
Feb 10, 2024 at 1:55 AM
BENLEE1199
  • 82 POSTS
See answers to your questions below...
No, I was on the freeway when the CE light went on, and I think 2,000 RPM's is typical for 50-60 MPH for my vehicle.
No, I did the scan when I got home, after the CE light had already come on, and the freeze frame said 50 MPH
No, I'm in Texas, but it was not hot out at the time. Maybe around 60 degrees or so.
Feb 11, 2024 at 11:37 PM
  • 55,766 POSTS
Can you do another scan without the freeze frame on? Engine off, key on. It seems like the PCM might be bad.
Feb 12, 2024 at 1:28 AM
BENLEE1199
  • 82 POSTS
Sure, I can do that. I added a battery terminal shim/cap to my negative battery terminal, since it could not be tightened 100%, and when I started the car after doing that the CE light had gone away. I'm surprised that just disconnecting the negative cable would reset the CE light, but if/when it comes back on, I will check it again as you mentioned and report back. Thanks!
Feb 12, 2024 at 4:21 AM
  • 55,766 POSTS
You are welcome please let me know what happens.
Feb 13, 2024 at 12:35 AM
BENLEE1199
  • 82 POSTS
I re-checked with a code reader as you described, key on, engine off, and got the same code P1381 and no additional codes. Here is the freeze frame data from the 2nd time:
FUELSYS1: CL
FUELSYS2: N/A
LOAD_PCT(%): 49.8
ETC (F): 181 (exact same as last time)
SHRTFT1(%): 0.8
LONGFT1(%): 1.6 (was -1.6 last time)
MAP (inHg): 14.7
RPM: 2080
VSS (mph): 53
IAT (F): 126 (was 122 last time)
TP(%): 16.1
Also, two days ago when driving home from work, I suddenly had some more serious surges from the engine, with the RPM rappidly jumping up around 500RPM 5 or 6 times in a row...then it returned back to normal. It did that about 2 different times that day. The next morning when driving to work it did not do that at all, but one time it felt like it downshifted a gear for about 5-10 seconds like I described previously, but no noticeable change to the RPMs during that time. Again, not sure if it is actually down-shifting, but that's what it felt like. Either way, the rapid surging that happened yesterday was a much bigger deal.
Yesterday when driving home from work, and this morning when driving into work...no issues at all.
Feb 14, 2024 at 9:36 PM
  • 55,766 POSTS
These are not good, but they might be caused by the crankshaft sensor issue. I would send the ECM in for testing.
RPM: 1951 ?
VSS (mph): 50 ?
These are not right. Let me know what they say.
Feb 15, 2024 at 9:12 AM
BENLEE1199
  • 82 POSTS
Fixed. I replaced the alternator and so far, have driven over 150 miles and no Check Engine light and no engine surging or drivability issues whatsoever.
Previously the CE light would come back on within a few miles of driving, and the surging/drivability issues would start happening within anywhere between 5~30 miles and continue at random for the duration of the drive (my commute is 1 hour+).
I was trying to avoid sending in the ECM, due to both cost and the fact that my commuter vehicle would be out of commission during that time, and some research showed that a faulty alternator could cause the suspect sensor to malfunction, triggering the code and other drivability issues...so I decided to try replacing the alternator, especially since I could return it for a refund if it did not solve the issue. I don't usually like to throw parts at the car and I always try to avoid doing that, but sometimes it is the best option, especially when it is a part that is fairly easy to access and replace on the vehicle. Luckily the issue was fully solved by the new alternator.
Anyway, I just wanted to give this update for the sake of others who may research this issue in the future.
Feb 28, 2024 at 12:54 AM
  • 55,766 POSTS
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Feb 29, 2024 at 4:03 AM
