Here is how to change the coils out with the spark plugs. Clear the codes once completed. Check out the images (below). Please let us know what happens.
Images (Click to enlarge)
Mar 4, 2025 at 5:31 AM
SAM CRENSHAW
MEMBER
Okay I checked the compression dry and wet, solid readings. Switched out the plugs. Here’s my question: do I need to replace the entire DIC? Attached is a video of the part.
Video (Click to enlarge)
Mar 10, 2025 at 2:00 AM
✓Experienced Mechanic
Yep, the DIC has a high failure rate and is a common replacement. Let, me know how it goes please. Clear the codes once completed.
Mar 10, 2025 at 3:40 AM
SAM CRENSHAW
MEMBER
Okay, replaced the DIC. Engine started and ran roughly then cut off. Got it to start a couple more times with the same result. Now won’t start.
Crankshaft position sensor?
Mar 14, 2025 at 4:58 AM
Hmm, yep, maybe the sensor is weak, and it causes false codes, here is the location of the sensor. Be sure to clear the codes once completed. Check out the images (below).
Image (Click to enlarge)
Mar 15, 2025 at 3:23 AM
SAM CRENSHAW
MEMBER
Just to be on the safe side, this is a Saab trionic for a turbo engine. Is there anything that I’m missing or not checking here?
Mar 15, 2025 at 6:02 AM
Do you have the same code? (P1301 code) is you replaced the coil I would replace the spark plug as well, even if it looks good, I have seen them have hairline cracks. Also, is the electrical connector at the coils looks to be in good shape?
Mar 17, 2025 at 2:15 AM
SAM CRENSHAW
MEMBER
Okay I have replaced the spark plugs, the DIC and now the crankshaft position sensor. The code has changed. The current code is P0327. Thoughts?
Mar 27, 2025 at 1:19 AM
Hello Sam, this is a knock sensor code. When the engine is running it is making a noise that should not be there, can you please upload a short video from your phone?
Mar 27, 2025 at 1:58 AM
SAM CRENSHAW
MEMBER
Yes. Attached. As you can tell, it’s having a tough time starting up and will die eventually. I have to apply gas to keep it running and then eventually doesn’t want to start at all.
Mar 27, 2025 at 11:50 PM
Thanks for the video. To me it sounds like the cat is clogged, this is what is making it stall so fast. I would loosen the head pipe on the exhaust manifold and start the engine to see if there is a difference.
Mar 28, 2025 at 3:10 AM
SAM CRENSHAW
MEMBER
Okay, what a bear that was. It’s still behaving the same. One thing I just found out: my wife put supreme gas in, realizing that she should not have been using regular, and topped it off with a container of Seafoam. It was shortly after this that it happened.
Apr 2, 2025 at 1:07 AM
Yes, it can be bad gas, I would try starting fluid into the intake to see if you can get the engine to stay running. Is there a chance that diesel fuel was put into the car?
Apr 2, 2025 at 4:02 AM
SAM CRENSHAW
MEMBER
Omg I hope not.
Apr 2, 2025 at 5:04 AM
SAM CRENSHAW
MEMBER
Okay, so with a spray in it will fire up for a second and then shuts off. I can try it ongoing, but I’ll need to wait to have a second person to help me. What do you think?
Apr 3, 2025 at 12:01 AM
Yes, I would try that, we need to know if fuel is the issue which this test to tell us.
Apr 3, 2025 at 2:33 AM
SAM CRENSHAW
MEMBER
Okay, starter fluid gets it to fire up for a second, but it won’t keep running.
Apr 4, 2025 at 7:26 AM
When you did the compression test and you said "solid readings" what were they?
Apr 5, 2025 at 3:42 AM
SAM CRENSHAW
MEMBER
Okay, I needed a new fuel pump. Replaced that along with a new fuel filter. Only issue now is code p0327. Everything’s running fine. I’ve reset codes and it keeps coming back on.
Apr 20, 2025 at 2:30 AM
That is the first time a fuel pump solved a "P1301 code is related to Ignition Coil #1 Open Circuit or Short to B+. "
That I know of, please start a new thread for the p0327 code.
