Code P1299, cylinder head temperature sensor overheating?
114,000 MILES • V6 • 2WD • AUTOMATIC
JUJUMAN723
This was the code feedback. My car overheated and my engine light came on. I changed my thermostat and refilled the coolant. The temperature seems to be stable, but the check engine light is still on. I took it out on the road, drove for about 45 minutes and it seems good, but that light is still there. A/C works both cold and heat, both fans working, no leaks. I'm not sure why the engine light is still on. Thanks in advance.
Jul 12, 2022 at 8:10 AM
SQM
  • 6,383 POSTS
So, have you tried to reset the code?
Usually, the engine light won't go away unless it is reset.
Here is a guide on resetting the light:
https://youtu.be/ahK_eucFi-k
Let me know of any questions.
Jul 12, 2022 at 12:53 PM
JUJUMAN723
Thank you. I am just worried that there is something else. I will get the code cleared and run again. I'll follow up soon.
Jul 13, 2022 at 12:01 AM
SQM
  • 6,383 POSTS
Sounds good. If the issue does not exist then the engine light will not come back on.
Jul 13, 2022 at 3:30 AM
JUJUMAN723
Engine light is gone. Thanks.
Jul 17, 2022 at 11:25 PM
SQM
  • 6,383 POSTS
Awesome!
Thank you for using 2CarPros.
Jul 18, 2022 at 12:42 AM
