Codes P1274 and p1283?
98,000 MILES • 3.5L • V6 • TURBO • 2WD • MANUAL
TBRATT11
Hello, I am having the same problem as https://www.2carpros.com/questions/p1283-nightmare but I am getting the code for both. I have the turbonetics turbo kit installed had it for about a year and now I am getting the codes. I have replaced both o2s. Can't seem to find the problem.
Jul 10, 2023 at 11:03 PM
  • 55,746 POSTS
This can be a vacuum leak, low fuel pressure/delivery, bad fuel injectors or a bad. Please go over this guide:
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
I have seen the MAF sensor cause this problem.
The P1274 and P1283 codes in a 2004 Nissan 350Z are related to the air-fuel ratio and indicate issues with the Bank 1 or Bank 2 Air-Fuel Ratio (A/F) Sensor. Here's some information about each code:
P1274 - Air-Fuel Ratio (A/F) Sensor 1 Lean Shift Monitoring Bank 1
P1283 - Air-Fuel Ratio (A/F) Sensor 1 Lean Shift Monitoring Bank 2
Use this guide when the engine is cold only:
The fuel pump could be getting weak as well. Check out the images (below). Please let us know how it goes
Jul 11, 2023 at 10:35 AM
