Long story short, this car sat for a long time while I was away. When I came back the battery was dead. Someone was supposed to keep the engine turned over at least once a week and let it run. Well that never happened. When I came back the car would not run and the fuel has sat for almost a year.I changed the battery, drained the fuel, cleaned the fuel pump and filter, replaced the gasket on the fuel pump. I was able to limp her home and the engine was running bad. Little to no power and then surging RPMs. I looked on the forums and did some more work. I took apart the air filter housing, replaced the air filter, replaced all the spark plugs, pulled the MAF and cleaned it with MAF cleaner, Pulled the throttle body and cleaned it with throttle body cleaner.I have done the throttle body relearn, but have no clue if it works.When I let the car reach the correct running temp the idle will surge from about 1500 to 1800-2000rpm. It will then drop back down and repeat this forever.If the car is placed in drive the rpms will drop down to the correct readings and the car seems fine. I cant really take her out on the road is the registration / insp has expired and the car cant be inspected until the problem is corrected and the mil is out.I did notice that if I am revving the engine and let it off the rpm will jump around before coming back down. On the small test drives around the streets around the house. I noticed the rpms can be erratic if I gun the engine and let off right away the tachometer will jump around too.The MIL light came back on and it read P1273. I looked this up and see that it is a code related to o2 sensors and other things.I'm looking for some help. I have gone to a Nissan dealer before and they tried to screw me over so bad for simple repairs and I don't trust a dealer anymore. They only want money and "throw parts and the problem" I prefer to troubleshoot the problem and get the "right" part. could someone please direct me in the right direction. I don't have a ton of money to dump into this car to chase this problem.The car is a 2005 Nissan Sentra 1.8dohc approx. 90K Thanks for any help that you can provide.
Feb 23, 2014 at 10:33 PM
