Codes P1188 and p1189 after CCV replaced
176,000 MILES • 6 CYL • 2WD • AUTOMATIC
ZELLDOG93
  • 111 POSTS
After replacing CCV I am receiving these codes and rough idle at start up.
Jun 17, 2018 at 9:29 AM
  • 55,594 POSTS
Please clear all codes and with the scanner still connected turn the key to the on position without cranking the engine over to see what comes up. Does the engine run?
Cheers, Ken
Jun 19, 2018 at 4:51 AM
ZELLDOG93
  • 111 POSTS
The day after I posted I found the o-rings went bad on fuel injectors. Waiting for them to come in today to continue. Thinking there was a small leak I did not see, but not sure if it would set these codes.
Jun 19, 2018 at 8:41 PM
  • 55,594 POSTS
Oh yes, it could cause all kinds of problems. Did the codes clear?
Jun 20, 2018 at 3:34 AM
ZELLDOG93
  • 111 POSTS
I got it back running cleared the codes and it came back. Here are recent freeze frames.
Jun 20, 2018 at 10:12 AM
ZELLDOG93
  • 111 POSTS
It has got bad lag causing traction to activate and rough start up idle and poor idle when stopped.
Jun 20, 2018 at 10:14 AM
  • 55,594 POSTS
By these numbers is looks like the MAF is having an issue which can be caused by a MAF sensor problem or a partially clogged catalytic converter. Here are two guides to help us see what the problem is:
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
and
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Cheers, Ken
Jun 21, 2018 at 5:24 AM
ZELLDOG93
  • 111 POSTS
Could this cause traction control to activate?
Jun 21, 2018 at 7:57 AM
  • 55,594 POSTS
Not really that would be a separate issue. Do you think that is what is slowing the car down? Can you make a quick video of the problem and upload it in your response so I can what is going on?
Jun 22, 2018 at 2:38 AM
ZELLDOG93
  • 111 POSTS
Sorry, I just saw this. I am more concerned with the check engine light. I got a new MAF and installed in no light, but I am getting this now:
Jun 25, 2018 at 10:38 AM
ZELLDOG93
  • 111 POSTS
These misfires appear when at idle.
Jun 25, 2018 at 10:39 AM
  • 55,594 POSTS
How does the engine seem to run? If okay I would say the computer is having an issue. Please remove the PCM and look for water damage. If you clear the codes and then just turn the key on without starting the engine do any codes come up?
Jun 26, 2018 at 4:18 AM
ZELLDOG93
  • 111 POSTS
Runs much better than before, but will notice the mis at idle. I cleared codes key off and no code were present have not looked at PCM just yet.
Jun 26, 2018 at 8:28 PM
ZELLDOG93
  • 111 POSTS
The first code to pend is p1622.
Jun 26, 2018 at 8:56 PM
  • 55,594 POSTS
This code is for the thermostat sticking open which can cause some issues. Can you please remove it to see if it is stuck open?
This guide will give you an idea for what you are inf for:
Cheers, Ken
Jun 27, 2018 at 5:42 AM
ZELLDOG93
  • 111 POSTS
I will get needed parts and install. I will let you know how things go.
Jun 27, 2018 at 12:06 PM
  • 55,594 POSTS
Sweet!
Jun 28, 2018 at 5:00 AM
ZELLDOG93
  • 111 POSTS
What is the possibility it is fuel related?
Jul 4, 2018 at 3:13 AM
  • 55,594 POSTS
These codes are oxygen sensor related can you make the sensors are plugged in? Also, if you have the wiring connectors off of them or any other sensor please check then to make sure they are plugged into the right place. BMW does not have unique electrical connectors of each sensor. It could be fuel related like bad gas. How did it run before you did the repair?
Jul 4, 2018 at 8:34 AM
ZELLDOG93
  • 111 POSTS
About the same. I feel it is running worse because of this extreme heat.
Jul 4, 2018 at 2:50 PM
ZELLDOG93
  • 111 POSTS
I noticed a code for fuel pressure today as well p1250 code.
Jul 4, 2018 at 2:51 PM
  • 55,594 POSTS
That can be a clue. Can you take a video of the way the engine running so I can see what is going on?
Jul 5, 2018 at 4:19 AM
ZELLDOG93
  • 111 POSTS
I can probably send you a live feed from module. Also, not sure if this could be related but my fuel gauge fluctuates while driving by almost a quarter tank.
Jul 5, 2018 at 8:53 PM
ZELLDOG93
  • 111 POSTS
I have also noticed it takes a second or two longer then normal for it to start up.
Jul 10, 2018 at 10:46 PM
  • 55,594 POSTS
Can you take a video of the way the engine running so I can see what is going on? Use your phone and upload it here.
Jul 13, 2018 at 10:19 AM
ZELLDOG93
  • 111 POSTS
Yes, I forgot to do that.
Jul 15, 2018 at 11:24 PM
ZELLDOG93
  • 111 POSTS
Let me know if you need more my speedometer is currently inop 7.
Jul 16, 2018 at 12:59 PM
  • 55,594 POSTS
If the speedometer is not working that would indicate the vehicle speed sensor is not working. Here is its location so you can swap it out.
It sounds like the engine is running good from what I could hear.
Check the plug maybe it got bumped in the repair somehow.
Check out the diagrams (below). Please let us know what you find.
Cheers, Ken
Jul 17, 2018 at 4:33 AM
ZELLDOG93
  • 111 POSTS
I was under the impression the speed sensor was through ABS. I am waiting for s o bushing long story short bought the car for $24.00 knowing it was a project. $200.00 parts later and now sensors and electrical started up. Could this sensor cause these two returning codes? With random intermittent codes for misfire? I am getting the fuel pressure regulator this week just to be sure I am not afraid to dump money in it for new parts car sat for almost five years.
Jul 17, 2018 at 10:21 AM
  • 55,594 POSTS
These kind of projects can snowball, but if the speedometer is not working that is job one because it can cause all kinds of additional issues the car must know its speed.
Jul 18, 2018 at 3:06 AM
ZELLDOG93
  • 111 POSTS
Okay.
Jul 18, 2018 at 2:27 PM
ZELLDOG93
  • 111 POSTS
So I went to replace the speed sensor that supposed to be on the differential and I cannot seem to find any harnesses or anything that looks like the sensor has be deleted. Is is possible the speedometer is read through right rear ABS?
Jul 22, 2018 at 6:18 AM
  • 55,594 POSTS
I found more information that they put them to two places. Here is the one that is in the transmission. Check out the diagrams (below). Please let us know what happens.
Cheers, Ken
Jul 23, 2018 at 2:43 AM
ZELLDOG93
  • 111 POSTS
I am going to be getting an order ready. What would be best temperature wise to install for the thermostat?
Jul 27, 2018 at 2:24 AM
  • 55,594 POSTS
I would go for the 192, because the computer needs to see heat to go into closed loop sooner.
Jul 27, 2018 at 3:32 AM
ZELLDOG93
  • 111 POSTS
Okay thank you. I noticed it is running around 226. Also getting a code p1622. So I am thinking I have a wiring issue as well.
Jul 28, 2018 at 5:20 AM
  • 55,594 POSTS
It does sounds like a wiring issue. here is a guide to help you test the wiring and the engine wiring diagrams please make sure the wiring is going to the correct sensor because BMW does not use dedicated connectors:
Here are the engine wiring diagrams below.
Cheers, Ken
Jul 29, 2018 at 4:56 AM
