Codes P1151, po171 and po174
163,842 MILES • 4.6L • V6 • 2WD • MANUAL
JACKNUT
  • 65 POSTS
These codes keep popping up. Truck will sometimes run rough or skip a little and eats gas. it use to only throw a slow acting 02 sensor code, but now it's doing this. no vacuum leak or intake leak.
Sep 28, 2019 at 6:42 AM
  • 55,782 POSTS
This is common when the MAF sensor needs to be replaced. here are two guides to help us fix the problem:
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
and
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
Sep 29, 2019 at 9:36 AM
