p1133 code
150,000 MILES • 1.3L • 4 CYL • 2WD • AUTOMATIC
TIN MAR KO KO
Engine check light.
Jul 12, 2017 at 12:07 AM
  • 55,676 POSTS
This codes means there is insufficient switching of the oxygen sensor which means there is either a vacuum leak or and engine misfire or the sensor is bad.
Here are some guides that will help you get the problem fixed.
and
and
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
Please run this test and get back to us we are interested to see what it is.
Cheers, Ken
Jul 12, 2017 at 5:03 AM
