P0845 with NO flashing D light.
2002 HONDA CRV
208,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
ALOHA168
  • 52 POSTS
Replaced 3rd clutch pressure switch and 3.1 qts of transmission fluid.I did NOT clear the DTC code with scanner or disconnect battery due to losing I/M readiness.My car registration/smog check is due in 3 days.I drove the car for 2 days and was hoping the ECM/PCM will clear it with no success.What should I do next?Do I need to manually clear the code?How long will the ECM take to clear the code?Should I clear the code manually and do the drive cycles to rebuild the I/M readiness?My car/transmission drives good other than that.Please help.Thank you.
Feb 22, 2023 at 9:24 AM
