Codes P0780 and P1706
211,000 MILES • 3.2L • V6 • 2WD • AUTOMATIC
01KAGCARPRO
These codes came up after the VSA and engine light came on.
Nov 9, 2017 at 5:00 AM
  • 31,937 POSTS
Both transmission codes,
P1706
Possible causes faulty transmission range switch transmission range switch harness is open or shorted transmission range switch circuit poor electrical connection
P0780
Possible causes low transmission fluid level dirty transmission fluid faulty shifting solenoid valve shifting solenoid valve harness is open or shorted shifting solenoid valve circuit poor electrical connection
I would get a transmission specialist to investigate these problems, as there is a desired level of knowledge required to investigate these problems first hand.
Nov 9, 2017 at 7:48 AM
