Code P0741
200,000 MILES • 2.0L • 4 CYL • AUTOMATIC
JOSEPH PAUL CORBETT-AMY CORBETT
Intermittent shift problem.
Light comes on after a while.
Aug 16, 2021 at 5:01 AM
  • 110,248 POSTS
The code is related to the torque converter clutch. It is stuck in the off position. This could be a wiring issue, low line pressure, or the TCC clutch solenoid.
I attached directions below related to the code. The attachments include a description of the code and how to diagnose the problem.
Aug 16, 2021 at 3:21 PM
FAHD1
Hello, I have a problem with the CVT automatic gearbox Hyundai Accent 2016 model. Malfunction code p0741 has been renewed inside the automatic gearbox, but the RPM is not stable. 40 and above, the same malfunction and the problem is due. They knew that I replaced the torque converter, cleaned the valve body, replaced some of the control sensors, and checked the connection wires. What is the problem?
May 19, 2023 at 1:30 AM
  • 110,248 POSTS
The code deals with either a faulty DC solenoid valve or the TCM. However, I need to ask a favor. We try to keep the threads specific to one type of vehicle so that it is more helpful to others. Could you copy and paste your question to a new post?
Here is the link to do it:
I hope you understand.
May 19, 2023 at 3:26 PM
