Code P0717 input speed sensor replacement
100,000 MILES • V6 • 2WD • AUTOMATIC
RDHINDSA
Where is the input speed sensor located?
Nov 18, 2020 at 2:01 AM
FREEMBA
  • 1,152 POSTS
The input speed sensor is located inside of the transmission pan.
The input speed sensor (ISS) is a hall-effect type sensor. The ISS mounts to the control valve upper body assembly and connects to the control solenoid
(w/body and TCM) valve assembly through a wire harness and connector.
Nov 18, 2020 at 3:53 AM
RDHINDSA
Thank you! If I were to drop the pan, the ISS should be easily accessible for replacing?
Nov 18, 2020 at 4:33 AM
Good afternoon,
I attached the procedure for the replacement for you.
The valve body has to be removed to gain access to the speed sensor.
Nov 18, 2020 at 6:05 AM
