Codes P0717 and P0301, how to fix it?
81,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
CYPHERTC
My car has a P0717 and a P0301 code. I replaced the TCM valve body and the output speed sensor. I'm still getting the p0717 code and the car shifts fine up to 3rd gear but will not go past that. Just revs very high to build speed. Close to 5 rpms at around 80 mph. Please help!
May 22, 2023 at 3:12 AM
  • 55,721 POSTS
Here are the codes:
P0717 - Input/Turbine Speed Sensor Circuit No Signal:
P0301 - Cylinder 1 Misfire Detected:
We handle one problem per thread so this thread will will fix the P0717
Here is the location so you can check it out. I would check the condition of the wiring as well. Check out the images (Below). Please let us know what happens.
May 22, 2023 at 8:39 AM
CYPHERTC
Unfortunately, I replaced the output revolution sensor in the diagram and the TCM module which has the input turbine speed sensor on it. I still have the same issue. Any other suggestions?
May 22, 2023 at 11:20 PM
  • 55,721 POSTS
Does the transmission fluid seem burnt and does the transmission slip? this can cause this code as well.
May 23, 2023 at 6:40 AM
