Code P0715
188,481 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
LOVETOY65
Trying to locate the Input transmission turbine speed sensor. Please help. I need a schematic.
Mar 1, 2017 at 3:13 AM
CARADIODOC
  • 34,414 POSTS
P0715 - Input/Turbine Speed Sensor Circuit Malfunction
Ford wants the location to be kept secret. There is no drawing of it, only a description. It is listed as rear of transaxle, left rear lower side of engine compartment.
The wire colors are dark green / white and gray / red.
If you find a dark blue / yellow and a gray / red, that is the output speed sensor.
Mar 1, 2017 at 8:27 AM
LOVETOY65
Thank you so much!
Mar 1, 2017 at 9:02 PM
  • 55,721 POSTS
Caradiodoc is one of our best!
Please use 2CarPros anytime, we are here to help and tell a friend.
Best, Ken
Mar 4, 2017 at 3:16 AM
