P0706 Code issue Civic CVT?
130,301 MILES • 1.8L • AUTOMATIC
STEVIE127
I have a permanent P0706 code and did my research and deducted that it was the neutral safety switch/range sensor. I went ahead and replaced it however the permanent code is still appearing. the car shifts fine and the it recognizes all correct gears (PRNDL). The wiring also seem fine, no corrosion or fraying when I was replacing the sensor. How could get to the root problem relatively quick and cheap? (It's my only car/daily)
Oct 7, 2026 at 1:44 PM
STEVE W.
  • 15,423 POSTS
How long has it been since you replaced the parts? A permanent code only clears once the vehicle completes a set number of drive cycles without detecting a fault. For that one it is normally 3 trips, but it can take more if there are any pending codes or other issues preventing the test from running.
Oct 8, 2026 at 9:22 PM
