Code P0642 sensor reference voltage a circuit low
160,000 MILES • 4.6L • V8 • 4WD • AUTOMATIC
LENNIE PATTON
  • 6 POSTS
I'm getting this generic code P0642 with four flashing red lights indicating a failure in one or more of the following areas: (the red lights) (1) evap sensor monitor (2) oxygen sensor monitor (3)oxygen sensor heater monitor (4)catalysts sensor monitor. This has been a nightmare trying to figure out what is going on. I've replaced the cam and crank sensors, fuel pressure sensor and now it won't even start.
Mar 19, 2019 at 7:48 AM
SCGRANTURISMO
  • 4,897 POSTS
Could you please double check the Direct Trouble Code (DTC) number again. I show no listing for DTC P0642.
Thanks,
Alex
2CarPros
Mar 19, 2019 at 8:27 AM
LENNIE PATTON
  • 6 POSTS
It's a generic code. Sensor reference voltage A circuit low. The red lights indicate a malfunction of some sort.
Mar 19, 2019 at 8:42 AM
LENNIE PATTON
  • 6 POSTS
I had the alternator checked today and it is good.
Mar 19, 2019 at 9:45 AM
LENNIE PATTON
  • 6 POSTS
Thanks for all the help. Must have missed it.
Mar 20, 2019 at 1:31 AM
  • 55,709 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Mar 23, 2019 at 8:03 AM
LENNIE PATTON
  • 6 POSTS
There was no answer only a question that I answered and never got a reply.
Mar 24, 2019 at 3:32 AM
  • 55,709 POSTS
Sorry I am not sure what you are saying?
Mar 25, 2019 at 3:32 AM
LENNIE PATTON
  • 6 POSTS
I gave the code P0642 and was told to check it again because they couldn't find a p0462 code. I explained it's a generic code saying "reference circuit low" then gave information that I had my alternator checked and it checked good. I never got any answer back.
Mar 26, 2019 at 1:32 AM
LENNIE PATTON
  • 6 POSTS
I even sent a picture of the Ob2 scanner with the code pulled up on the screen.
Mar 26, 2019 at 1:33 AM
  • 55,709 POSTS
Sorry about that. I thought you were saying the alternator was bad and they missed it. anyway lets check fuse number 24 on the left side of the drivers compartment for power. If okay lets test the wiring between the alternator and PCM/cluster and if okay the PCM or cluster is bad and needs to be replaced. here is a guide to help us get started and the alternator wiring diagrams and fuse locations so you can do the test to confirm the issue:
and
Mar 26, 2019 at 5:48 AM
