Code P0507?
119,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
VILLALTABRIAN428
Hello, so, I have the car listed above LX model. A new code popped up PO507. The car is running fine. The only symptom is idle is high when car turn on, RPMs 1,5000 and after it gets to normal temperature goes down to 1,000 RPMs. The throttle body is clean, and I already tried the relearn twice. Any ideas on how to fix this issue?
Sep 10, 2024 at 5:14 PM
AL514
  • 5,685 POSTS
Hello does your scan tool read live engine data? It sounds like you probably have a vacuum leak somewhere. Or an input such as the power steering switch or a charging system issue can also cause a high idle, due to the extra loads those put on the engine.
but the first thing I would check is the live engine data on the scan tool, and look for the Long Term and Short Term Fuel Trims (LTFT and STFT). If the percentage is positive such as above 10%+ you can then raise the rpm to about 1500-2000rpm and you should see that Fuel Trim number come down towards 0% or at least below 10%. That indicates a vacuum leak, If it is a vacuum leak, the best way to find it is using a smoke machine on the intake manifold, its the quickest and safest way to find a leak,
You can also try unplugging the Purge valve, if it is stuck wide open and the ECM has no control over it, its basically a vacuum leak as well.
In scan data also check the Engine Coolant temperature sensor readings, this vehicle has two of them according to the wiring diagrams, one might be for the Clusters gauge and the other for the ECM.
Try unplugging the Power Steering Pressure switch too, its on the power steering line, its a 2 wire connector, if the idle comes down, (it may take a minute) but you'll know thats causing the high idle.
Ill put up a picture of the power steering switch and Purge valve locations
https://www.2carpros.com/articles/automotive-engine-vacuum-leak-symptoms
Sep 11, 2024 at 7:45 AM
AL514
  • 5,685 POSTS
Here some locations of components that can cause a high idle besides a vacuum leak.
Sep 11, 2024 at 7:50 AM
