P0481&P0481 p/d error codes
123,000 MILES
MARK JOHNSON
I followed your response on a similar problem and when I start the engine with a/c on the fans run. I cleared the code and it has returned. What do you recommend that I do next. Thank you for your help.
Jun 15, 2013 at 1:40 AM
HMAC300
  • 48,601 POSTS
the fans are supposed to run with a/c on. check for a shorted wire a bad relay
Jun 15, 2013 at 4:45 AM
MARK JOHNSON
can I check the relay by swapping #1 and the #3? If so what should I be looking for? I also want to thank you for your help!
Jun 15, 2013 at 4:50 AM
HMAC300
  • 48,601 POSTS
yes you can swap out relays with any like relay.
Jun 15, 2013 at 5:19 AM
