P0453 FTP HIGH truck has a fuel cell all evap remAins
81,000 MILES
CLENZER72
  • 14 POSTS
I have a fully custom 01 ranger , 3L V6. Body dropped, shaved, airbagged, you name it, it's been done....except fix that little red light.
Due to the lowered stance of the truck I had to install a fuel cell, 20gal aluminum, we retained the stock pump and filler neck, however, the vent at rear we did not. There's a port at one corner we used to T into the vent line from the pump to the FTP, there it then T's out to the engine bay and the canister.
We just did all the electrical tests, voltage, resistance, continuity, ect and everything was in spec. I think I may need to change the routing of the hoses and the sensor. Can you suggest how this should be done? Should the FTP BE in the port of the fuel cell and the vent from the pump goes to canister and engine bay?
California smog is tough, I need to get this MIL off just in case there's other issues. This code doesn't let the other monitors run.
Thanks for your help.
May 10, 2013 at 11:15 AM
what tests??? what were the results??? if all the readings were correct, you would have this issue.
roy
May 10, 2013 at 11:25 AM
CLENZER72
  • 14 POSTS
We checked for continuity from PCM to bulkhead, then bulkhead to sensor=ok
We also did the various checks on the PCM Pins and the Sensor
lFTP V PID. If PID voltage was 4.9
We did all the checks here:
"33) DTC P0453: Check FTP Sensor Voltage Turn ignition on. Using scan tool, select FTP V PID. If PID voltage is more than 4.5 volts, go to next step. If voltage is 4.5 volts or less, fault is intermittent. Go to step 42). 34) Check For Short To Power Turn ignition off. Disconnect FTP sensor connector, located on top of fuel tank. Turn ignition on. Measure voltage between FTP terminal at FTP sensor wiring harness connector and negative battery terminal. If voltage is 10.5 volts or less, go to step 36). If voltage is more than 10.5 volts, go to next step. 35) Check FTP Circuit For Short To VPWR Circuit Turn ignition off. Disconnect PCM 104-pin connector. Inspect connector for loose, damaged or corroded terminals. Install Breakout Box (014-00950), leaving PCM disconnected. Turn ignition on. Measure voltage between test pins No. 62 and 103 at breakout box. If voltage is more than 10.5 volts, repair short circuit. If voltage is 10.5 volts or less, replace PCM. 36) Check Opposite Induced Low FTP Signal Turn ignition off. Connect a jumper wire between SIG RTN and FTP terminals at FTP sensor wiring harness connector. Turn ignition on. If scan tool communication link error is displayed, remove jumper wire and go to step 41). Using scan tool, select FTP V PID. If PID voltage is less than .1 volt, remove jumper wire and go to next step. If PID voltage is .1 volt or more, unable to induce opposite signal. Go to step 39). 37) Check Voltage At FTP Sensor Connector Measure voltage between VREF and SIG RTN terminals at FTP sensor wiring harness connector. If voltage is 4-6 volts, go to next step. If voltage is not 4-6 volts, VREF voltage is out of range. Go to CIRCUIT TEST C . 38) Check For Short Circuit Turn ignition off. Disconnect PCM 104-pin connector. Inspect connector for loose, damaged or corroded terminals. Install Breakout Box (014-00950), leaving PCM disconnected. Measure resistance between test pins No. 62 and 90 at breakout box. If resistance is more than 10,000 ohms, replace FTP sensor. If resistance is 10,000 ohms or less, repair FTP circuit short to VREF circuit. 39) Check For Open FTP Circuit Turn ignition off. Disconnect PCM 104-pin connector. Inspect connector for loose, damaged or corroded terminals. Install Breakout Box (014-00950), leaving PCM disconnected. Measure resistance between test pin No. 62 at breakout box and FTP terminal at FTP sensor wiring harness connector. If resistance is less than 5 ohms, go to next step. If resistance is 5 ohms or more, repair open in FTP circuit. 40) Check For Open SIG RTN Circuit Measure resistance between test pin No. 91 at breakout box and SIG RTN terminal at FTP sensor wiring harness connector. If resistance is less than 5 ohms, go to next step. If resistance is 5 ohms or more, repair open in SIG RTN circuit. 41) Check FTP Circuit For Short To VREF Circuit Measure resistance between test pins No. 62 and 90 at breakout box. If resistance is more than 10,000 ohms, replace PCM. If resistance is 10,000 ohms or less, repair FTP circuit short to VREF circuit. 42) Check For Intermittent Open Or Short To Power Turn ignition on. Using scan tool, select FTP V PID. Observe FTP V PID for indication of fault while shaking and bending FTP sensor wiring harness and connector. A fault will be indicated by a sudden change in FTP V PID voltage. Tap lightly on sides of FTP sensor to simulate road shock. DO NOT tap on top of sensor. If fault is indicated, isolate fault and repair as necessary. If no fault is indicated, go to CIRCUIT TEST Z . NOTE: A break in step numbering sequence occurs at this point. Procedure skips from step 42) to step 44). No test procedures have been omitted"
Since the only next step is to replace the PCU.... , that's a pricey alternative to re-routing the hoses and moving the sensor to the proper location.
I didn't do the disassembly of this area and two people at separate times reassembled the evap system......not sure if they knew what they are doing.
A detailed diagram of all hoses and connectors in their spot for my year make and model would be awesome, but I can't seem to find one, all the diagrams I've seen vary slightly from the actuals of my 50 state legal system
May 10, 2013 at 12:47 PM
what was the reference voltage as asked????
i have seen these things go all the way to the end, check out ok and the fuel pressure sensor is still bad. i replaced the sensor and all was good. make sure your reference voltage is good
roy
May 10, 2013 at 12:53 PM
CLENZER72
  • 14 POSTS
All the voltages were within tollerance.
I'll have to find the sheet of paper that I kept notes on to update.
I guess the placement of the FTP doesn't matter too much???
Attached should give you a rough idea of placement
May 10, 2013 at 8:17 PM
CLENZER72
  • 14 POSTS
FTP Voltage, VPID was 5v (4.9)..within spec
Ref Volt was less than 10.5 at 5v
FTP SHort to PWR was 5.2v....in spec
FTP Circuit short to VPWR was less than 10.5 at 5v..in spec
Open SIG RTN circuit between PCM and FTP Harness was .3ohm...in spec.
I went to the yard this weekend to see about picking up an used FTP to test, and also get the Vent valve at the rear of the tank, as well as verify hose routing...however, there were only pre 01 trucks with the non-return style system so I couldn't compaire.
Can someone verify the path of each hose to component? IE, vent valve->hose to "T1", Fuel Pump vent->hose to "T1", 'T1" ->hose to canister...ect or whatever makes since to explain.
Considering I am not using a stock tank, but a fuel cell with stock pump, and a hose instead of the the seperate vent valve,
I know, custome isn't many of your expertise, however, I thought someone might know more than the Workshop Manual tells you to do......Like your FTP needs to be here in line with this hose...your getting that error becuase the fuel cell doens't....blah blah blah.
But this one is a little challenging and out of the norm so I understand.
I have some other interesting issues, but I'll keep those for a rainy day:)
Thanks for your help, I have broused the site and learned some things I didn't know. the team is knoweledgable and the site definatly has helpped me in other ways
May 13, 2013 at 8:30 AM
CLENZER72
  • 14 POSTS
So know body knows custom installs in Cali that can guide me through this?
I'm sure it's not the wires or the sensor, I've determined it's the hose routing, but I can't find anything detailed enough to show me how/where to route
Jul 13, 2013 at 6:18 PM
