Scanned car and found p0453 code for fuel tank pressure sensor. Alldata shows the sensor to be on the right side rear of the engine compartment, however there is no sensor there other than the EVAP purge flow switch and the Evap purge solinoid. I have also checked around the fuel tank with no luck. Any Ideas on where else it could be or if its possible that the car isnt equipped with one? And if not equipped, what else could cause this code?
May 14, 2013 at 1:53 AM
