p0443 code
131,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
FREDNAN
This truck does not have a canister purge valve that I can find.
Oct 22, 2017 at 11:57 PM
SATURNTECH9
  • 30,869 POSTS
I posted a diagram of where it is.
Oct 24, 2017 at 1:52 AM
FREDNAN
This truck does not have one at this location. I have seen this diagram before and none of the vacuum hoses match. The truck has no pressure sensors in the gas tanks or a purge valve on the canister. The system looks like what ford calls a probe system but it has no purge valve on the charcoal canister. I replaced the vacuum control valve now the problem is intermittent, but I still get a p0443 code.
Oct 24, 2017 at 3:37 AM
SATURNTECH9
  • 30,869 POSTS
That truck lists that code on my online repair information and the top fix for the code is to replace the canister purge solenoid.
Oct 24, 2017 at 6:11 AM
SATURNTECH9
  • 30,869 POSTS
That is from the wiring diagram for your truck it is called a vapor management valve in the wiring diagram.
Oct 24, 2017 at 6:15 AM
SATURNTECH9
  • 30,869 POSTS
I posted the three types of valves they use on your truck.
Oct 24, 2017 at 6:21 AM
FREDNAN
That is what i replaced the vapor management valve. Could i have a vacuum leak with this code? i cannot find a canister purge valve. Thank you
Oct 24, 2017 at 6:38 AM
SATURNTECH9
  • 30,869 POSTS
Yes, you might have a leak. I posted a couple more diagrams that will be helpful I would say the management valve would be the equivalent to the canister purge valve.
Oct 24, 2017 at 6:50 AM
FREDNAN
The diagrams are what i have. I am searching for leaks now. Thanks for the help. You confirmed that there is no separate vent purge on this truck. Thanks again.
Oct 24, 2017 at 6:57 AM
SATURNTECH9
  • 30,869 POSTS
Your welcome keep us posted.
Oct 25, 2017 at 1:01 PM
