P0442 Code?
72,460 MILES • 1.2L • AUTOMATIC
AULDPOP
Confirmed by dealer to be a leak in the vacuum hose running from fuel tank to evap purge solenoid.
Replacement part no longer made by GM.
question - can the vacuum hose be repaired?
Sep 22, 2026 at 2:56 PM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Ask the diagnosing shop to identify the exact leaking section and record the original part number, line material, diameter, connector type and any molded fittings. Check for a superseded replacement using the VIN before concluding that no service option remains. If the damage is confined to a serviceable section, ask a shop experienced with EVAP systems whether an automotive gasoline-vapor-rated repair tube or hose and matching connectors are approved for that material and application. A suitable sectional repair may be possible, but ordinary vacuum hose, rubber cement, tape and unspecified glue are not substitutes for a verified vapor-line repair. Do not disable the EVAP system. After repair, have the shop repeat the specified EVAP leak test with appropriate equipment and confirm monitor operation under the vehicle's prescribed conditions. Clearing P0442 alone does not demonstrate that the leak is sealed. Fuel odor or visible liquid leakage warrants prompt inspection away from ignition sources. A discontinued original assembly does not automatically mean the car is beyond repair. Identifying the line precisely gives a specialist a practical way to evaluate compatible replacement or repair options.
Guidance references and applicability
Dorman gasoline vapor repair line kit, product 800-180: https://www.dormanproducts.com/p-30440-800-180.aspx Manufacturer example showing that purpose-made gasoline-vapor repair components exist for specified applications. This is not a fitment recommendation for the Chevrolet Spark; its dimensions, materials and applicability must be checked. The leak location and discontinued-part report come from the owner's account of the dealer diagnosis. The original part number and diagnostic report were not provided.
Read the replies · Discussion summary and reported outcome
MECHTRIX
  • 586 POSTS
Best to just buy one at a auto part store and chang it yourself or any regular shop should be able to do it cheaply ..its common gotta get the old one off and bring it in to get the right size but its cheap usually about $5 to $10 they sell it by the foot not sure how much youl need but they can cut whever length you need of you never changed the gas cap you might want to look at that too most evap leaks are simply be uas of an old gas cap....anyway good luck hope this helps
Sep 22, 2026 at 5:17 PM
AULDPOP
Mechtrix,
thx for the reply !!
addressing a couple of points...
-> technician at the chevy place outright stated there is no replacement available. None from GM as they changed design and quit making the old ones appx 3 yrs ago.
-> The repair receptionist stated she looked for anything that offered it as an aftermarket approved by GM as being feasible. I confirmed this at home before I posted the original question. All the usual car parts online shops noted for that old of a Chevy spark, there was nada/zio/etc that would work.
Now being bold, I look at reddit car repair forums a bit. Best advice they gave was to try and repair.. or disable the EVAP solenoid completely. Ummm no on the disable.
have looking through auto savage forums. no bueno.
so, looks I drive it until it won't start completely .. or spend some coin on a diffwrent vehicle.
Sep 22, 2026 at 6:31 PM
MECHTRIX
  • 586 POSTS
The code 8s for a tiny pin hole of a leak its amd evap problems dont effect the way it runs to much you won't evan n8t8ce anything except for the code that said its usually a simple hose the easy to get a d you just plug it in and thats it maybe its a special hose for some reason ..I you find the leak wich is gonna be hard to do maybe be uase its gonna be small you could just oatch it with rubber cement ir somthing and youl proba ly neve see that cide again is my guess but first you gotta find it a d take it of just pull off in sure unless they put special plug-ins on it ..if you find it pleas post a phiti here so we can see what it evan is we're talking about there lots of different type of hoses on the car but im sure its gonna be a pretty easy fix hope this helps good luck
Sep 22, 2026 at 7:22 PM
Discussion summary
P0442 Code?
The owner reported P0442 and said a Chevrolet dealer had located a leak in the vapor line running from the fuel tank toward the purge solenoid. The owner also reported that the original replacement was discontinued and that searches for a suitable alternative had been unsuccessful. The discussion considered hose repair, but no verified repair material, replacement assembly or completed fix was documented.
Reported outcome: The owner reported a dealer-identified line leak, but no completed repair or successful retest was reported.
Parts availability and the proposed line repair have not been verified for this VIN. P0442 alone does not identify the leaking component. The discussion does not establish that a no-start is imminent or that replacement of the vehicle is necessary.
Read the original discussion
