What color smoke do you see? Also, the code indicated an issue with the evap system's purge valve solenoid. This solenoid is actuated by engine vacuum, which can be causing drivability issues. However, there also are several electrical components involved.
If you are seeing dark gray/black smoke from the exhaust, there is a chance the system is running too rich due to a vacuum leak.
I attached the diagnostics below for this code. Take a look through them and let me know if it is something you are comfortable doing.
Images (Click to enlarge)
Sep 23, 2021 at 1:11 PM
