p0441 I checked the purge valve?
129,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
YAZIDAN
  • 141 POSTS
p0441 purge incorrect flow. I checked the purge valve it seems to open and closes. when the purge valve is purging the fuel tank pressure sensor did not go down to vacuum it stayed at 3.46 KPA but ESIM switch went to closed. after I open the gas cap , fuel tank pressure sensor stayed the same at 3.46 KPA. ( the scan tool i have does not use InH2O or Hg ) .it that seems like a bad fuel tank pressure sensor or could be something else? also what the gas tank fuel pressure should be in KPA when the gas cap is open?
Dec 10, 2025 at 7:49 AM
  • 55,658 POSTS
yep, this sounds like the pressure sensor is bad, here is the location so you can swap it out to help fix the problem, be sure to clear the codes once the repairs are completed.
Normal FTPS values (key on, engine off): Typically around 0 kPa (atmospheric pressure) It will drift slightly ±0.3 kPa depending on altitude and temperature.
When you open the gas cap: FTPS should immediately drop to approx 0.0 kPa. If it stays unchanged - sensor is stuck or the reference hose/port is blocked.
The sensor is on the fuel tank with the fuel pump. Check out the images (below). Please let us know what happens.
Dec 11, 2025 at 2:23 AM
YAZIDAN
  • 141 POSTS
do you know if there is an access hole underneath the back seat to get to it. also, what you mean by reference hose/port is blocked. also can I get the wiring diagram of the connector like that i can check 5v ref ground and signal for circuit integrity
Dec 11, 2025 at 2:51 AM
  • 55,658 POSTS
If the hose from the purge valve might be pinched shut so the vacuum never makes it to the tank so please check that, there is no access port to the tank so it will need to be removed and the gas drained first, this video can help with that.
https://www.youtube.com/watch?v=Q5MH2gnyFH0
Here is the wiring diagrams so you can see what is going on and how the sensor works. Check out the images (below).
Dec 12, 2025 at 12:12 AM
YAZIDAN
  • 141 POSTS
AllData gave you the wrong information. the sensor is located on a hose underneath the rear right liner fender. I checked by unplugging the connector. the pressure went down to minus 820 Pa. I am glad the sensor is NOT on the gas tank. this is a short video where is located .
https://youtube.com/shorts/2CR0k_HLvb8?si=8his6WISyZ0-WIoy
Dec 12, 2025 at 1:54 AM
  • 55,658 POSTS
Perfect nice work! This will help others.
Dec 13, 2025 at 12:46 AM
YAZIDAN
  • 141 POSTS
the FTPS was replaced. check engine light is off but p0441 is a permanent code. how many drive cycle I need to drive to clear the code by the PCM. is there a fast way to be done?
Dec 22, 2025 at 7:36 AM
  • 55,658 POSTS
Yes, I would use a scanner to clear the codes, this video should help.
https://www.youtube.com/watch?v=ahK_eucFi-k&pp=0gcJCU0KAYcqIYzv
Please let us know what happens. Ken
Dec 23, 2025 at 2:09 AM
YAZIDAN
  • 141 POSTS
yes, I did use scan tool to try erase the code. but because it's a permanent code. the scanner cannot erase the code. the computer will erase it when it sees that the fault is gone. but I want to know how long will take the PCM to erase the code?
Dec 23, 2025 at 10:01 AM
  • 55,658 POSTS
If the code comes back even though you have not started the engine or run it for any length of time I would say the PCM is bad. You can remove it and send it in for testing these guys do a good job:
https://www.flashmastersecm.com
No code is permanent they all should be able to be cleared and then the code will come back if there is a problem. Let me know what happens.
Dec 24, 2025 at 2:04 AM
YAZIDAN
  • 141 POSTS
I checked the PCM today the code is gone by itself without erasing it, two monitor still not ready the Evap and o2 sensor.
Dec 24, 2025 at 6:53 AM
  • 55,658 POSTS
Yep, you will need to drive the car through serval how and cold cycles for the monitors to reset. Please go over this guide to help
https://www.2carpros.com/articles/how-to-reset-an-engine-computer-monitor-program
Please go over this guide and get back to us.
Dec 25, 2025 at 2:39 AM
YAZIDAN
  • 141 POSTS
Hi
passed emission thanks.
Dec 29, 2025 at 12:22 PM
  • 55,658 POSTS
NICE! Use 2CarPros anytime, we are here to help. Please tell a friend.
Dec 30, 2025 at 1:46 AM
