P0431 and P0421 codes?
2008 MITSUBISHI GALANT
271,018 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
MATTSTORMS42
  • 26 POSTS
Have dtc codes p0431/p0421. Put new "cat" and new 02 sensors. Cleared codes. Car drove fine before and after new parts were put on. Codes returned after a day of new parts were put on. What else could be the problem? What other test can i do to solve the codes?
Nov 8, 2025 at 6:25 AM
  • 55,423 POSTS
Strange that is has bank 2 on a 4 cylinder since there is only bank 1, hmm anyway I would check the engine cooling system thermostat, does the car have a engine temperature gauge, and if so does it stay on the cold side for a long time? This can mean the engine is not warming up fast enough and it will give you these codes.
P0421 - Warm-Up Catalyst Efficiency Below Threshold (Bank 1)
P0431 - Warm-Up Catalyst Efficiency Below Threshold (Bank 2)
If you find the thermostat stuck open replace it and then clear the codes which should fix the problem. Please upload a short video in your response of the problem, so I can see what's going on :)
Nov 10, 2025 at 1:44 AM
MATTSTORMS42
  • 26 POSTS
1 hour of driving. Back roads and minimal highway.
Nov 10, 2025 at 7:08 AM
MATTSTORMS42
  • 26 POSTS
After riding for an hour in morning 29 degrees
Nov 10, 2025 at 9:01 PM
  • 55,423 POSTS
hmm sorry this website is having an issue so I cant see the images can you just tell me where the needle is, or you can upload a short video those are working.
Nov 11, 2025 at 1:55 AM
MATTSTORMS42
  • 26 POSTS
Picture of scanner readings. Before and after pics of fuel gauge.
Nov 11, 2025 at 6:39 AM
MATTSTORMS42
  • 26 POSTS
Temp took from 4:21pm to 4:43 to reach mid point of temp gauge on dash
Nov 11, 2025 at 6:40 AM
  • 55,423 POSTS
Yep, way to long, it should be at operating temperature with in 5-7 minutes, I would install a new thermostat and then clear the codes. Can you just tell, (type) me the codes?
Nov 12, 2025 at 3:36 AM
MATTSTORMS42
  • 26 POSTS
P0431 and p0421
Nov 12, 2025 at 8:46 AM
  • 55,423 POSTS
lol sorry, I thought here were more codes then what was listed, after doing more research I found that the Galant 2.4 is notorious for the front cat (manifold cat) going bad. When both P0421 and P0431 show together, that’s classic. So you replaced the front or rear cat?
Nov 13, 2025 at 2:37 AM
MATTSTORMS42
  • 26 POSTS
Replaced front cat. I thought it only has 1? I replaced all 4 02sensors and cat
Nov 13, 2025 at 7:42 AM
MATTSTORMS42
  • 26 POSTS
All 1 piece
Nov 13, 2025 at 7:46 AM
  • 55,423 POSTS
Sorry, the site is still having an issue, so the front cat is made into the exhaust manifold, is that what you replaced? If not this will be the problem.
Nov 15, 2025 at 1:12 AM
MATTSTORMS42
  • 26 POSTS
Yes sir
Nov 15, 2025 at 3:58 AM
  • 55,423 POSTS
So is this a v6 engine?
Nov 17, 2025 at 12:53 AM
MATTSTORMS42
  • 26 POSTS
2.4 inline 4
Nov 17, 2025 at 6:35 AM
MATTSTORMS42
  • 26 POSTS
Picture of catalytic converter
Nov 17, 2025 at 6:48 AM
  • 55,423 POSTS
It is so strange that you have bank 2 on a four cylinder, some generic scan tools will label downstream sensors as "Bank 2" or assign “Bank 2” codes to rear/secondary oxygen sensors. If so if you had these codes before the cat swap and you still have them I would say the PCM is bad. I would remove it and send it out for testing.
Nov 18, 2025 at 2:21 AM
MATTSTORMS42
  • 26 POSTS
Ok thanks
Nov 18, 2025 at 4:31 AM
  • 55,423 POSTS
Please let me know what happens.
Nov 19, 2025 at 12:21 AM
MATTSTORMS42
  • 26 POSTS
Yessir
Nov 19, 2025 at 2:38 AM
