P0430 code
2009 SATURN OUTLOOK
150,000 MILES • 2WD • AUTOMATIC
ARG2413
About three months ago a p0430 code popped up on my check engine light. The bank 2 catalytic converter was replaced also all four sensors. The code went away for about a month and then popped back up again today. What could be the possible problem?
Aug 4, 2018 at 1:01 AM
Good afternoon.
What kind of catalytic converter did you use?
Quality is critical. If it was a cheap one, they never last. You need a good quality converter made by Walker or Bosal.
The precious metals inside is what is not doing its job. The cheaper ones do not have enough to keep the light out.
Aug 4, 2018 at 5:40 AM
ARG2413
It was walker.
Aug 4, 2018 at 5:41 AM
They have a warranty on them. I would return to the installer and have it replaced again.
Does the engine run good? Engine misfires can cause a catalytic converter to fail but you did not mention any of this in your post.
Aug 4, 2018 at 6:06 AM
ARG2413
The engine runs great. Car drives smooth.
Aug 4, 2018 at 6:12 AM
Okay, ask them to warranty your catalytic converter. It has at least a one year warranty.
Aug 4, 2018 at 6:20 AM
ARG2413
I bought it and did it myself.
Aug 4, 2018 at 6:21 AM
Okay, did you fill out the warranty card and send it in when you bought it?
Aug 4, 2018 at 6:29 AM
