Code P0420?
203,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
TWEBB101
  • 183 POSTS
A couple of days ago my check engine light came on. Plugged a scanner in and got P0420, but that was it, no other info. Google says catalytic converter or O2 sensor. Can you help?
Oct 18, 2024 at 2:52 PM
  • 110,248 POSTS
A P0420 indicates the catalytic converter is operating below threshold. In most cases, the converter needs to be replaced.
What you could do is this. Using an infrared thermometer, check the catalytic converter intake temperature and compare it to the outlet temperature.
If the converter is working properly, the outlet will be hotter. Take a look through this link, it explains what I suggested in more detail and other things to check:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Let me know if this helps or if you have other questions. Note: If there is an oxygen sensor that is failing, there would be a code specific to the sensor.
Oct 18, 2024 at 3:11 PM
TWEBB101
  • 183 POSTS
Thanks Joe. I ordered a temp gun and then the check engine light went away. :) I'll watch it and see what happens.
Oct 22, 2024 at 11:51 PM
  • 110,248 POSTS
Thanks for the update. It sounds like you have the same luck as I do. LOL
Regardless, let me know if things change or if I can help in any way.
JOe
Oct 23, 2024 at 12:22 PM
