Okay, I'm copying all this data, as for the scan tool protocol type, I wouldn't worry about that too much, you were able to get onto the vehicles network and retrieve data, it looks like that's just the global OBD2 protocols and the scan tool searching for the correct one to communicate on. You could try updating the scan tool. There are constant updates for them. For the fuel trims, just pay attention to the data PIDs with Short Term/Long Term Fuel Trims, having the trims pulled up for each 02 sensor will just slow your scan tool down because its having to read more data, The less data PIDs you have up the faster the scan tool will refresh the live data.
When looking at fuel trims, just add the bank 1 LT and STerm together to get the total fuel trim for each bank, so looking at a frame of the trims you posted, Bank 1 +8.6(short term) and -5.5(long term) equals out to +3.1 total trim. Which is not bad, interesting both banks are stuck at -5.5 LT.
But if you were to graph that 02 data from the rear sensors you would see them fluctuating at a frequency that is too high for rear 02 sensors, that shows the cats are not storing oxygen which they need to be able to for burning off and converting the left over combustion gases.
What's the deal with all these codes? I know you said they were historic, but were they set prior to some repairs? Because that's a lot of concerning codes, misfire codes on every cylinder is not a good sign, I'm going to go through and look them up just to have a list. Along with the Cat temperatures in Fahrenheit (915f & 906f). If that data is correct, which I think those are estimated values, the reason why the Cat Eff codes are setting is because of the rear 02 voltage fluctuations. The voltage reading should be a much steadier, 600-700mv range or so, just not the high frequency you're seeing such as in the example waveform below.
If there were repairs done, and the cylinder misfires were taken care of, plus all the other code issues, this might be the aftermath and result of those previous cylinder misfires and possibly and over-fueling problem. I have heard of some people attempting to clean cats out or certain treatments, although I've never tried any, so I can't recommend something I haven't seen work myself.
The freezeframe data is from saved data from when specific codes set, so you would have to identify what code that data went with, one thing I see that's not good is the "fuel rail pressure at idle- 11890 kPa" - Thats 1724.49 psi at idle, I dent think that's within spec, and that is probably what set the fuel rail pressure sensor code.
I also see a P0137 B1S2 low voltage, more concerning is this 508-798psi @ idle for rail pressure, 1724.49psi would set a code.
The calculated cat temperatures look high to me as well, Id check them with a laser temperature indicator to see if they are actually that high, check the front and rear of each cat. Hopefully they are not already starting to melt down.
I've seen cats actually get so bad they melted plastic components on the engine. Glowing red when driving down the road, that's when they break apart and clog up the exhaust melting into a blob of rare metals,
To check if they have started to melt, you can do a back pressure test at either front oxygen sensor location, pull the sensor out and I use an adapter from an old 02 sensor hollowed out that has a hose on it, which I then hook my vacuum gauge too, the cheap kind that also go up to 10psi positive pressure. Hook it up and start the engine, you only need a quick reading at idle, then have someone rev it up once or twice while monitoring the gauge, if it goes over 1.5-2psi max, the cats are starting to melt down and restrict the exhaust. If they are reading 2psi at idle, it will jump up much higher with a quick rev, then you know the cats are done unfortunately. But that's the way to determine if they are beyond recovering. Don't leave the pressure gauge on the exhaust long, just a few seconds to get some readings.
Really it depends on the back story of this vehicle, with 42 codes set and some very apparent fueling faults in the past, it would explain the cats just having been so abused.
I'm going to look up these other codes.
Images (Click to enlarge)
Mar 12, 2025 at 12:57 PM
