p0411 will not go away
60,000 MILES • 6 CYL • AUTOMATIC
KRYPTECLIPSE
  • 45 POSTS
I have changed the secondary air pump as the code says and I still get the same message. I have checked all around for leaks and cannot find any. The hoses are new and the car drives perfect. I erase the check engine light but it comes back on after a day or so. Thanks in advance.
Mar 4, 2016 at 2:58 AM
HMAC300
  • 48,601 POSTS
See the pictures for things to check. It should be 9-18 volts on tests
Mar 4, 2016 at 4:11 AM
