P040 code
2000 TOYOTA TACOMA
128,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
JIM116
  • 5 POSTS
Burns no oil, regular tune ups, runs excellent. Gave inefficient catalytic converter code once on highway trip so I decided to change both O2 sensors since they were old. Now shows P040 code after ten to twenty miles of low speed driving. Installed two new Denso of correct numbers, no exhaust leaks, catalytic converter at inlet about 500 plus degrees.
Any ideas what to try next ? Thanks.
(P.S. California emissions vehicle)
Jul 25, 2018 at 5:39 AM
Good evening.
Can you please verify the code? You are missing a number at the end.
Jul 25, 2018 at 8:06 AM
JIM116
  • 5 POSTS
Sorry about that, P0420, bank 1 low efficiency.
Jul 25, 2018 at 8:12 AM
Okay, thanks.
You need a catalytic converter. There is no issue with the O2 sensors at all. The fact that the rear O2 voltage is reading the same as the front is the reason the code set. The rear should be steady and not going up and down like the front.
The precious metals are worn out internally and the catalytic converter needs to be replaced.
CIRCUIT DESCRIPTION
The ECM observes the wave form of the heated oxygen sensor located behind the catalyst to determine whether the catalyst is performance has deteriorated. If the catalyst is functioning normally, the wave form of the heated oxygen sensor located behind the catalyst switches back and forth between rich and lean much more slowly. When the wave form of the heated oxygen sensor located behind the catalyst alternates flatteringly between rich and lean, it indicates that catalyst performance has deteriorated.
Jul 25, 2018 at 8:19 AM
JIM116
  • 5 POSTS
Thanks, I was hoping it was not that. One more question. With the old 02 sensors I went many weeks since the first P0420 code and never came back on. As soon as I put two new Denso O2’s in it started to show the code every day. Is that common? Are the new sensors just more sensitive or accurate in measuring the imbalance?
Jul 25, 2018 at 8:31 AM
The new ones are just more sensitive.
It sounds like you cleared the code, the light went out and did not come back on until the PCM tested the converter and it failed its internal test three times in a row.
Clearing a code does nothing. The issue has to be addressed.
Jul 25, 2018 at 8:44 AM
JIM116
  • 5 POSTS
Thank you. : (
Jul 25, 2018 at 9:41 AM
You are welcome. Keep us updated and do not be afraid to come back with more questions.
Jul 25, 2018 at 9:42 AM
JIM116
  • 5 POSTS
I would gladly update on how it goes, but I think it will be awhile since I do not have emissions test for awhile and I will just run it until then. Thanks again.
Jul 25, 2018 at 9:45 AM
You are welcome.
Jul 25, 2018 at 9:46 AM
