loss of power, rough idling, vehicle stalls. I like to know how many sensor banks the vehicle has. Any one can help me with the diagram.
Aug 19, 2019 at 6:27 AM
94 TRANSAM
✓Experienced Mechanic
Hi Andrin, thank you for using 2CarPros. Lets see what we can do here.
I am happy to give you the sensor information you asked for, but this code is specific to the #5 ignition coil failing. Would you like all the sensor information or would you like some help with this code? I am happy to help either way.
Rich.
Aug 19, 2019 at 2:06 PM
ANDRIN ATEM
MEMBER
Thanks very much for replying. Nissan Navara d40 2006 4 cylinder diesel engine. Do you know the position of the crank sensor, or which coil should i check?
Aug 19, 2019 at 4:42 PM
94 TRANSAM
So you have a code PO335 not a PO355 as your post title says? Correct?
